Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
My iPhone 5 only works properly when it’s charging
My iPhone 5 fell in water and I got it fixed. As of right now my phone screen is very unresponsive and rarely works and if it does work it is very frustrating to use. The only way it works properly is when it charging. I also have tried about a 100 times to restart my phone and even hard resetting it, and it hasn’t worked. What do I do?
Add a comment
Most Helpful Answer
You said when you plug in your phone The touch works right? In this case all you need to do is a battery replacement.
iPhone 5 Battery
If this wouldn’t be the issue it wouldn’t be worth it to fix the phone it would be cheaper to buy a new one.
iPhone 5 Battery Image
Product
iPhone 5 Battery
$29.99
Score 2
3 Comments:
Too expensive. Any other way?
by
Change the battery to a phone damaged by liquids that has not been cleaned, it is not advice, it is silly. The first thing is to disconnect the phone and not turn it on until you clean it. If you have turned it on and used it, make a backup and recycle it correctly since it will not last long.
by
Read this please. You should know before advising @scottpine Electronics Water Damage
by
Add a comment
You said your phone was dropped in water. How long from the time it was dropped to the time you had it fixed? Water damage repair has to be done a quickly as possible otherwise corrosion starts and can lead to all sorts of problems. Typically when we get devices that have been dropped in water we have to replace the screen. Did you get a new screen put on? That part that worries me a little is that it works fine when you have it plugged in. Batteries also tend to need to be replaced after being dropped in water. From past experience, Apple products do act funny when they have bad batteries. I would see if a local repair shop could test on of their batteries in your phone first to see if it fixes the problem. If it doesn’t then you likely have some other issues that need to be addressed.
Score 2
4 Comments:
I brought it to get fixed about maybe 3-5 days after it fell into water.
by
I would see if a repair shop would try a battery for you first to see if this is the problem. I fear that with you waiting that long that something on the board might have gotten damaged. Best case is that a new battery fixes your problem.
by
Any other solution?
by
I unfortunately don't have any other ideas for you. If it was me, I would try a battery next. Just ask a local repair shop if they will test if for you for free. Connecting a new battery to the phone takes just a few minutes.
by
Add a comment
Add your answer
Gurleen Dhillon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 151
