The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197 Questions View all
Can I replace my 600 watt psu with a 1000 watt one?
Hello I have a powermac g5 dual 2.5 gb. The 600 watt psu died and I was wondering if I could upgrade it to the 1000 watt used in the pm quad core? Are they compatible? Thanks for any help in this matter
Score -1
Add a comment
1 Answer
Chosen Solution
No, 1000W power supplies use different connectors than the 600W and are therefore incompatible. However, you can replace the 600W power supply in your machine with a (Slightly Cheaper) 450W power supply, because they are compatible.
Score 2
1 Comment:
The only problem would be a restriction on the number of devices the computer could support. ( Two hard drives instead of four--limited number of cards installed--etc.) +
by
Add a comment
Add your answer
Jason will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,036
