Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Questions View all
Home Button Only Partly Functional
Hello all. I recently replaced my screen with the one that I bought from this site. Everything seemed to go well enough, no nicked ribbon cables or anything.
However, after replacing the screen and booting the phone up, my home button only has some of its functions. The phone has even automatically given me the artificial home button on the screen, because the phone knows there’s something wrong. It still recognizes my touch ID and I can even sometimes wake the phone up with the home button, although there’s no “click” from the tap engine. Also, when I am actually using the phone, I’m unable to get to the home screen by pressing it. I have to use the artificial home button on the screen.
Wondering what this could be caused by. I thought I was careful enough. Again, no nicked cables, quadruple checked all connections to make sure they’re snug, loosened / removed the screw from the back of the home button. I’m not sure if I might have used too much heat, because I’m not sure what would be typical in this case. I used a hot, wet wash cloth and pressed my saran-wrapped phone into it for about a minute to loosen up the glue. Had to do it multiple times because that glue was really tough.
Any suggestions appreciated.
Score 1
2 Comments
Status update, found out that the ear piece speaker doesn't work while making phone calls.
It WILL work when listening to voicemails, just not when making phone calls.
by
Ok. A little more of an update.
I am not able to receive texts or do FaceTime, despite the fact that the front camera works.
The only way I can contact people at this moment is through Facebook messenger.
by
Add a comment
Chosen Solution
The home button on the iPhone 7 and up are non repairable as they are software locked to the main board CPU. The reason why you are getting the Touch ID and not the click is you damaged the U10 chip located in the middle of the home button ribbon cable from most likely heat and prying it up. You have to be very careful when removing as it’s easily damaged during transfer to a new screen. As for your voicemail working on earpiece but not calling, it sounds like a software issue . Try restoring the iPhone to new via DFU mode and trying again… if not, I’d try replacing the front cam flex as that may have also been damaged during the screen replacement
1 Comment:
Excellent. Thanks so much sir. I will give those a shot replacing them.
by
Add a comment
Home Button is probably damaged. I suggest replace button yourself if you don’t want Touch ID. But if you want Touch ID, go Apple Service, where this will replaced.
1 Comment:
So the Touch ID works, so I’m not too worried about that. However, I’m now finding that the earpiece speaker doesn’t work when making phone calls. I’m beginning to think this might be a board issue?
by
Add a comment
Is sound like the person that replaced it rely messed up.
Add a comment
Add your answer
Robert Howard will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 85
