Home Button Only Partly Functional
Hello all. I recently replaced my screen with the one that I bought from this site. Everything seemed to go well enough, no nicked ribbon cables or anything.
However, after replacing the screen and booting the phone up, my home button only has some of its functions. The phone has even automatically given me the artificial home button on the screen, because the phone knows there’s something wrong. It still recognizes my touch ID and I can even sometimes wake the phone up with the home button, although there’s no “click” from the tap engine. Also, when I am actually using the phone, I’m unable to get to the home screen by pressing it. I have to use the artificial home button on the screen.
Wondering what this could be caused by. I thought I was careful enough. Again, no nicked cables, quadruple checked all connections to make sure they’re snug, loosened / removed the screw from the back of the home button. I’m not sure if I might have used too much heat, because I’m not sure what would be typical in this case. I used a hot, wet wash cloth and pressed my saran-wrapped phone into it for about a minute to loosen up the glue. Had to do it multiple times because that glue was really tough.
Any suggestions appreciated.
2 Comments
Status update, found out that the ear piece speaker doesn't work while making phone calls.
It WILL work when listening to voicemails, just not when making phone calls.
by Robert Howard
Ok. A little more of an update.
I am not able to receive texts or do FaceTime, despite the fact that the front camera works.
The only way I can contact people at this moment is through Facebook messenger.
by Robert Howard
