Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Questions View all
The phone was kind of soaked in a car fluid.
I had my phone in a jacket pocket. I placed the jacket on the floor of the car and when I arrived home I see that a car fluid got on my jacket. The phone was soaked with fluid. I wiped the phone down and I took off the back and I saw that there isn’t any water damage. The battery is fine. The screen is black but I can still power the phone on and the lights and sounds still work fine. What should I do?
Add a comment
1 Answer
Chosen Solution
Hi @:)hi
As you know water (or any liquid) and electronics and electricity are not a good mix.
The impurities in the liquids causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone, including, removing the shields and disconnecting any flex cables from their sockets and clean all the affected parts using Isopropyl Alcohol 90%+ (available at electronics parts stores) to remove all traces of corrosion and any liquid. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
Samsung Galaxy S5
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 2
Add a comment
Add your answer
:)hi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 53
