Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
It won't power up, or light up anything when plugged in.
It definitely needed a new battery, yet would that cause it to not turn on even when plugged in? More likely bigger issues, am I right? Any other reasons this may occur? I would like to save it. Thank you.
7 Comments
What is your exact model? Apple created a few different versions in the series A1297 models
by
What wattage is your mag-safe?
by
From the research I just did all 17" unibody Macbook Pros are model number A1297. 85w magsafe. Thanks guys.
by
This is a very desirable machine. Don't give up on us helping you to get it running. El Cheapo batteries are just that, don't do it even if you are tempted.
by
Show 2 more comments
Add a comment
1 Answer
Most Helpful Answer
Follow this guide MacBook Pro 17" Unibody Battery Replacement remove the battery, then press and hold the power button for a good 2 minutes to make sure the system is fully discharged. Now plug in your MagSafe charger and try to start your system. Let us know what you hear or see.
Score 1
2 Comments:
Will give this a shot when I get home, thank you all for your time!
by
Well I tried removing the battery and starting it without it. That was a no go, on the simple fix. Thanks anyways Dan.
by
Add a comment
Add your answer
Walter Stewart will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 81
