Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
iPhone 3GS Broken cable 3 latch
I have a IPhone 3gs. Recently replaced the digitizer glass for the second time. I broke off the latch on cable 3 and now the cable won't seat. Have had it apart several times, tried several things to seat the cable and have now damaged the connector. The cable is OK. I can seat it while the case is still open and the earpiece works. It works because, while it is open and the glass assembly is slid down past the case a little, it puts pressure on the cable to keep it seated. Once I snap the case together, the cable unseats and the earpiece stops working. I have seen on this thread where someone can replace or fix the connector. Anyone in Orange County CA that can repair this? Thanks.
1 Comment
larrygreene, great for asking your own question. Just delete your comment on the other question so that way nobody gets confused.
by
Add a comment
1 Answer
Chosen Solution
Type into Web search engine "connector 3 repair blog"
This is the place for connector 3 (or any connector) fix, also happens to be in Orange County California.
Score 1
1 Comment:
Try clicking on contributors.. Hector truong. He writes on here about iPhone problems and repairs this problem
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,450
