Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Questions View all
No output to built-in display. Tried the basic stuff. What now?
So I just tried to replace my high-res matte finish display with a glossy standard-res display. The install went fine but the machine wouldn’t boot. I diconnected the LVDS cable on the glossy display from the board and found that there were two contacts missing from the connector. So I contacted the vendor for a return and decided while I was waiting for a replacement, to put my matte display back in.
When I did, I now have no internal video at all but do have output from the mini display port. All cables are properly seated and I even cleaned the LVDS connector on the old display and it’s accompanying socket on the board with isopropyl alcohol and compressed air. Was static safe the whole time.
Any thoughts on what might have gone wrong would be highly appreciated. Not a newbie doing these types of repairs either.
Add a comment
1 Answer
Chosen Solution
The end pins are the backlight power. Sounds like you burnt the fuse.
Shine a flashlight through the Apple Logo are you able to see your desktop and its icons?
2 Comments:
I agree with dan, Check the Back Light for any signs of image. Look in the connector too. Just to be sure the pins that where missing are not broken off in the connector shorting something. Which pins on the connector where broken?
by
Yep, it was the fuse. Thanks to all who assisted.
by
Add a comment
Add your answer
Steven Wymor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 112
