Strange power/battery reoccurring issue
I'm facing an issue where my old MacBook Air's battery works.... sometimes.
When I unplug the power adapter, then the computer sometimes shuts down immediately, despite that the power adapter has been plugged in for a day. If the shutdown happens, then the computer behaves as if the battery is dead but then all of a sudden, maybe after a week, the battery starts to work like normal again (5 hours of battery, normal use). What could this be?
I can't replicate the issue and when I contacted apple then they do not know what could be wrong.
Not sure if it's worth mentioning but when the MacBook Air recovers from a sudden shutdown, then the time is set to January 1, 2018.
2 Comments
You'll need to check your MagSafe connectors. Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters
I would recommend you also install this app CoconutBattery so you can monitor your battery and its charging. Post a snapshot of the main window so we can also see its condition too! Adding images to an existing question
by Dan
Hi Dan,
Thanks for the fast reply! Took a screenshot of the battery stats. I looked at the Apple T/N but the only thing i could find, was that the dc cable is missing insulation. I have tried different cables when the problem occurs but it does not help.
by Anders
