Transfering files from dead MacBook to another MacBook using enclosure
Hi! Recently my macbook (due to water damage according to the apple store) completely died- the tech guy said that they could repair it, but there was no gurantee the data would be all there when repaired so he said I could try and use an enclosure to recover the files (link:https://www.amazon.com/gp/product/B00TQW...)
So I ordered it and followed the steps and plugged my dead mac’s hard drive into it and then the adapter into my sister’s (perfectly fine) computer. However, my files did not show up in disk utility or computer- could it be that my my hard drive is damaged beyond repair and I should just repair my old computer with the files? Or could I have done something wrong or something? Please help!!
Update (01/27/2019)
@mayer @danj @aactech Yes I was careful! It doesn’t show up anywhere- not on disk utility, terminal, or my desktop. Does this mean the files aren’t recoverable? Should I give up and have the apple techs repair the comp and start fresh? My sister has the same mac as me i think, and she was running yosemite and i was running high sierra.
6 Comments
There are a few different SSD's are you sure you got the correct case for your systems SSD?
by Dan
it said that it was compatible with my computer model.. does that count?
by Lucy jennifer
Hi Lucy,
Were you careful to discharge any static from your hands and not touch any of the circuits when you removed the hard drive and while installing it in the external case?
Did the drive show up in the Disk Utility but just not the files?
If so it may just be corruption of the file structure. If the files are very important a local techie may be able to help you. One with data recovery experience on MAC's!
For others reading this - MAC's are VERY, VERY fussy about parts and are very tricky to service. Unless you are a techie I would not touch them as you'll probably end up spending even more money.
by mike
what computer does your sister have and what system were you running and what system is she running?
by mayer
@mayer @mike @danj Yes I was very careful! It doesn't show up anywhere- not on terminal, disk utility or my desktop. My sister has a mid 2015 mac and was running yosemite, I was running high sierra i believe.
by Lucy jennifer
Show 1 more comment
