Dead MacBook after routine maintenance
Hi guys. I'm about to have a heart attack here. I was doing some routine cleaning of the inside of my macbook, something I had done many times before. This meant removing the upper case by disconnecting the keyboard (silver connector).
I then proceded to put it back together, connected everyting and powered it back on. It booted up by neither the keyboard not the trackpart worked, so I thought that I had probably not connected the upper case correctly. I re-dissassembled and reconnected the upper case wire. Tried powering on again but once again no keyboard or trackpad. Tried again but now I don't even manage to get it to power. If I connect the power adapter, the light does go on the connector but nothing happens.
I'm really scared that I killed my laptop.
Any advice?
Thanks!
Update: Just tried powering it on by shorting the two soldering points next to the fan and it works. Phew!!! So that means that it's probably a problem with the keyboard, or maybe just the cable or the connector? Given that there were no spills or anything of the sort, is it likely that the keyboard got damaged or could it be just the cable from the keyboard to the logic board?
However, being the pessimist that I am, is it possible that the connector in the logic board got damaged?? :-/
I'd appreaciate your experience on this which will hopefully help me get a good nights sleep!
4 Comments
Tell us your procedure for cleaning please.
by mayer
Hi Mayer.
Well no big deal really. Just followed the guide for removing the fan here in iFixit and cleaned all the dust that had settled in the fins of the heatsink. The just blew away some of the dust that had settledin the circuit boards and that was about it. Wasn't very thorough cleaning. Was mainly concerned with removing the dust from the heatsink as I had noticed an increase in the number of times that the fan went to full speed. It was indeed quite clogged. Then just put everything back (including the keyboard), and that was it.
by chssvl
Er, chssvl, which soldering points did you short to get it to boot? Can you post a link if there's a picture of it elsewhere?
by Bernie
Sure bernie. This is the picture that I found which I used as guide. http://forums.macrumors.com/attachment.p...
by chssvl
