Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
How to fix a cracked screen
I have an iPhone 6 phone. The phone has been dropped and has severe screen damage. Although the screen is damaged, the screen still works and the digitizer appears to be working.
I don’t know whether the ONLY the screen should get replaced or both screen and digitizer. Again, it appears the digitizer is ok and only the screen has been affected by the drop. I would like to repair it myself, if possible.
Add a comment
1 Answer
Easiest way to do this is to just replace the entire display assembly. Replacing the Digitizer only requires special equipment and skills.
iPhone 6 Screen
iPhone 6 Screen Replacement
Replace a screen compatible with iPhone 6.  Includes all of the small parts pre-installed in the assembly, saving time and increasing the quality of your repair. 4.7 inch 750 x 1334 pixel IPS LCD Display. Image
Product
iPhone 6 Screen
$44.99
2 Comments:
Thanks for the response. You suggest I should replace the LCD screen and digitizer? Which is the whole assembly.
by
Yeah because it requires special tools and skills to replace just the digitizer.
by
Add a comment
Add your answer
jkbmjp will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 162
