Repair and disassembly guides for GE Microwave ovens.
How to replace the handle on GE CSA1201RSS-03?
I have a CSA1201RSS03 Advantium microwave and want to replace the handle. I can’t find out how to get at the bottom screws to replace it. Any ideas?
Add a comment
Chosen Solution
Hi @mikeayl
Here’s an image taken from this webpage that shows an exploded view of the door of your model microwave oven.
Hopefully this is of some help.
(click on image to enlarge for better viewing)
Score 2
Add a comment
Most Helpful Answer
Here’s a video on how to do it:
https://www.youtube.com/watch?v=vw4PZYDc...
UPDATE
The videos don’t give specific models
So look at these:
https://www.repairclinic.com/Video/Video...
https://www.youtube.com/watch?v=KGb-U0t-...
Score 2
3 Comments:
Thanks for the reply but the unit in the video is much older than mine and the door configuration has changed. I can’t get at the bottom mounting screw because it is between the inner door (with the window) and the outer trim and I can’t figure out how to get the outer trim pieces separated from the inner door
by
To get to the bottom screw, you have to remove the outer plastic fascia from the interior core of the door. To do this, first remove the six screws fastening the door to the exterior plastic trim. Then CAREFULLY pry back the edges of the plastic trim to release the core from the trim. If you work slowly and carefully, you probably will not break anything here.
Once the exterior trim is free of the core, you will have access to the upper and lower screws that are used to attach the handle.
https://forum.appliancepartspros.com/pos...
by
Same issue I have. All these videos are of much older Advantiums.
by
Add a comment
Add your answer
Mike Aylward will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,434
