{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
276 Questions View all
Touch bar replacement Yay or Nay?
Hello Everyone,
this is my first question ever but i have been following this page for a quite a while since repairing apple products is kinda of a hobby of mine! Ironically enough, i managed to get water on my touch bar and Display!!!!The display is kinda okay and fully functional but the touch bar is completely out!
I also checked if this is due to a Software problem and noticed that “Touch bar agent and Server” are not running at all! Should they be running under “Activity Monitor” regardless of the functionality of the hardware?
Also, I am facing the problem of finding a touch bar and replacement guide! does anyone have any experience regarding this matter that would like to share?
MacBook Pro 13" Retina (Late 2016-2017) Touch Bar Assembly
Is this actually complete or do i need to purchase any extra parts?
Would you guys recommend replacing it myself?
I went to a shop that handles and repairs apple products and also and the official “Handler” but obviously they wanna change the whole top case and would cost me up to 800€ /910$ which is insane!
I would really appreciate your feedback on the matter since am a novice when it comes to new macs repairs!
Thanks in advance.
Cheers,
Magd
MacBook Pro 13" Retina (Late 2016-2017) Touch Bar Assembly Image
Product
$54.99
Score 1
16 Comments
@danj thanks man for your support! i will give it a try and most likely film everything/post it and make my first contribution to this great community =)
by
Hi there. Was wondering if you were successful in replacing the touch bar and if so, did you actually make a video?
by
I'm having similar problems. My touch bar is gone and macbook bricks or takes too long to function on wake and sometimes decides to reboot itself. I took a quick look inside and the logic board looks fine. Everything else works perfectly. If it wasn't for the occasional restarts and bricking on wake I could bear not having a touch bar. Would replacing the touch bar solve these issues?
by
If your touch bar is not functional it will mess up the OS as the interface driver between your TB will crash! So yes you will need to get it fixed.
by
This is exactly what happened to my 15" -- the touchbar gave up the ghost. The observed behavior was the computer would not wake from sleep and panic/restart. Upon loading up in Mojave, some "security update", that according to my research on the internet was a firmware update for the touchbar, would be forced and fail preventing startup.
This issue was fixed for me entirely by replacing the touchbar with a working one. It's definitely a somewhat unpleasant experience to pry the existing one out but I think was worth it.
FWIW having a USB-C ethernet adapter plugged in allowed me to boot the machine, but I was unable to find any config/software solution to prevent the panic-on-wake issue.
by
Show 11 more comments
Add a comment
Chosen Solution
Most likely they quoted a full uppercase replacement which is why is was so expensive.
As far as replacing the Touch Bar. Getting the old one out is a pain! You’ll need the peel the bar off in pieces as it’s well glued down. Review this teardown MacBook Pro 13" Touch Bar Teardown jump to Step 16. You’ll want to remove the display following this guide MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement and you’ll need to remove the Touch ID sensor reference Step 11 in the Teardown. Starting at the Touch ID hole that’s now exposed pry the Touch Bar out and clean the surface. I found a heat gun with a narrow tip can soften the glue, just becareful you dont melt the keys! I used foil which was glued over card stock and double stuck down to the case.
You’ll need Tesa 61395 Tape to re-attach the new Touch Bar if yours doesn’t have it on it.
Tesa 61395 Tape Image
Product
Tesa 61395 Tape
$5.99
MacBook Pro 13" Touch Bar Late 2016 Image
Guide
Difficulty:
Moderate
MacBook Pro 13" Touch Bar Late 2016 Display Assembly Image
Guide
Difficulty:
Moderate
1 - 2 hours
Score 5
3 Comments:
I had the 2018 13" model but made this guide after going through it myself : 2018 MacBook Pro 13" Touch Bar Replacement
by
@shldnet - Well done! I found a chisel knife worked best so you don't score the upper case as much. Even still not a fun job!
by
Add a comment
Just finished replacing the Touch Bar on my MacBook Pro 15” 2017. For anyone else attempting, on the 15” model I didn’t need to remove the display, but I did need to remove the logic board and the left fan to get to the flex cables that attach the Touch Bar to the logic board.
A few notes on my repair, I didn’t use a heat gun (didn’t have a small enough tip that would work without melting the keys). Took about 2.5 hours to completely remove the Touch Bar by slowly breaking it with tweezers and then using citrisolv and a metal splunger to remove all the adhesive and remittance. I wouldn't recommend unless you have the patience. Better to a heat gun with a small tip as mentioned by dan, just be wary of the keys.
Thank you Dan for the answer/links and Magd for posting!
Score 3
1 Comment:
Yes, you can get away without removing the display, I did it to make sure I didn't damage it in the process.
by
Add a comment
I just followed the instructions here on a 2017 15" MacBook Pro. Some clarifications to help anyone else attempting this...
Yes, it absolutely sucks removing the Touch Bar - you will have to remove the logic board and both fans to remove and replace the cables to the Touch ID button on one side and the Touch Bar on the other. You will NOT need to remove the screen, just the motherboard. You can start prying up, smashing, chipping and chiseling away the old Touch Bar after the Touch ID button is fully removed.
A heatgun can help but you will probably still melt something. Be sure to remove the top two rows of keys if you use one and BE CAREFUL! Also read how to remove the butterfly keys if you’ve never done it before. The heat gun is not necessary however and the Jimmy Tool from the essentials toolkit referenced below can be used to scrape up the remaining glue using an up-and-down scraping motion once the old Touch Bar is obliterated and it will be obliterated, it doesn’t just come off.
Tips:
Go slow, very slow, know what you're doing for every step. Be gentle with the cables. Read the guide for removing the screen on the machine as it relates to removing the logic board, it describes how to remove some tricky parts including the flat cables with a flip-up lock. The two cables at the lower left and right of the motherboard just lift up and out but are glued down. Just pull them up, not away from the connector.
Take a good picture of the logic board once the bottom cover is off before you do anything for reference later if you need it.
Take notes about what each part is as you remove it, where it was physically found, and what bit the screws are for reconstructing (use a project mat unless you have another strategy). When removing screws, be slow and use adequate downward force to avoid stripping them as you will be totally screwed if you do.
Final tip: Go slow, very slow, know what you’re doing for every step.
Recommended tools:
Essentials Toolkit - Essential Electronics Toolkit
P3 bit (not in kit) - iFixit Precision 4 mm Screwdriver Bit
Tesa Tape - Tesa 61395 Tape
(optional and helpful) Project Mat - Magnetic Project Mat
Necessary bits: T3, T5, TR8, P2, P5
I can happily say my MacBook finally works again and I can put it to sleep without it freezing when waking (or becoming a brick with that “security update” upon startup when upgrading to Mojave).
Thank you for this post and tips from other folks! It was a fun project to do but did take me several hours to complete so give yourself adequate time or plan to work on it in a couple of sessions. Good luck if you’re embarking on the same repair, it is possible!
Magnetic Project Mat Image
Product
$19.95
Essential Electronics Toolkit Image
Product
$29.95
iFixit Precision 4 mm Screwdriver Bit Image
Product
$2.99
Product
Tesa 61395 Tape
$5.99
Score 3
5 Comments:
The display does not need to be removed.
You can break cable of the spoilt Touch Bar and start from the side that does not have the Touch ID. In that way, you do not need to be afraid of spoiling the TouchID button. With some patience and consistent low heat, it can be pried out in 20 mins.
Clean the residue with an alcohol swab and a flat blade 90 degree pen knife tool. Can be done in 30-45 mins.
The shards are a pain to clean off. I use an industrial blower + vacuum.
by
Removing the display is not that big a deal once you've gotten the logic board out. I would recommend it for a fist timer. Removing the TouchID is just smart! If you slip you can kill it and it offers access from the other side.
You don't want to damage either if you slip up.
I tape down a strip of aluminum foil over the keys to protect them from both the heating of the area if you use a heat gun and to prevent the glass crumbs from getting caught in the keys.
by
Is replacing top case a easier way to go ?
by
@kirkmcphee - Yes, but more costly!
by
Thnx for info
by
Add a comment
Add your answer
Magd will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 46
All Time: 19,854
