Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Cracked Case?
Near the thumb-scoop there appears to be a small crack running parallel to the case (follows the curve of the scoop) and is about the length of the trackpad button. It is only small but is there something I can do without replacing the entire case?
Score 1
Add a comment
Chosen Solution
You have to show it to your local Apple Service Provider. I some cases Apple will repair the MacBook.
- shurai
Score 2
1 Comment:
It's not under warranty though
by
Add a comment
I see, so the top case actually has a crack in it. For a complete fix you will need to replace this. You can use this guide to carry it out.
Score 2
2 Comments:
I'd rather not pay $169 USD and just keep it as it is. It doesn't bother me so i will just leave it
by
I agree, maybe you could try shurai's suggestion?
by
Add a comment
If the crack is on the keyboard then they'll repair it at no cost. They said it is recognized as a design flaw. However if the crack is anywhere else then you'll have to pay for it
Add a comment
I have the same problem with my black macbook, I use black electrical tape to cover it, it's the perfect color, if you have a white macbook you could use white electrical tape.
Add a comment
Add your answer
AussieMac will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 1,662
