Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 Questions View all
Is this 3rd party battery out of spec for my iPod?
Most batteries I've seen is 3.7v. My new replacement 3000mah one says 3.8v. Is the increase of a tenth of a volt cause for concern? The battery says +LG 405570 3.8v 3000mah. It also doesn't match the text from the picture in the ebay auction which started with UK something.
2 Comments
I looked for you guide when posting my answer but it was not listed
by
Comment: Life is good!
by
Add a comment
Most Helpful Answer
@zombietechie
as long as it fits, it would be fine. Biggest issue here will be the charging time. The replacement battery you are referring to is a bit over 3 times as many mAh as the original. This is very difficult to achieve within the same size parameter. Make sure that these numbers a legit.
The voltage is fine and will not cause you any issue.
Score 3
Add a comment
See if you can use the iOS option using Coconut Battery and get a better idea of what this battery is doing.
https://www.coconut-flavour.com/coconutb...
Score 1
1 Comment:
@ajcooke01v2 maybe you should have given partial credit to the person who gave you the idea to make the guides.
by
Add a comment
Add your answer
Justin Ingle will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 381
