Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Can you double check my logic and maybe provide alternate ideas?
My situation is that I have two Core 2 Duo macbooks, model 2,1 and 1,1. One sustained a fall and basically still works as computer but screen is cracked, optical drive wont run and key board has some keys that broken of in a way that can't be replaced. The only thing wrong with macbook number two is a coffee spill. It won't charge the battery or run of the power adapter but will run on a battery that has been charged on another macbook.
I figure I probably have one fully functional macbook between the two. What I need to know is:
1. are these slightly different model numbers fully compatible for swapping out parts?
2. What is the best way to go about this in light of wanting to combine the display, optical drive, and keyboard from one mac with the logic board of the other. Should I think of it as a swapping of logic boards or cannibalizing a host of parts off of one back to the other? The former feels cleaner but the latter might be actually be less complicated and less work.
3. Is the logic board the firm culprit in the second macbook? Is there another possibility? Is there a clear spot where the logic board might be shorted that can be more easily repaired than the possible number 2 scenarios?
Score 1
Add a comment
1 Answer
Chosen Solution
hello, You can interchange the logic board of both . You can Make one working from both. do one thing take out the display clampshell from the spill and put in the broken one. if the broken one has any physical damage then you just interchange the logic board then you get the one working
here you can see:
MacBook Core 2 Duo Logic Board Replacement
Score 1
Add a comment
Add your answer
Aaron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 536
