Scientific calculator by Casio. Widely used by students world-wide due to its great quality for the low price.
37 Questions View all
Facing Problem on my calculator
My calculator is fully reversed. The number is reversed. Everything is rotated into 90 degree. How can i fix this problem?
Score 2
6 Comments
20°56°its answer plz solve
by
shift button is working only for offing the calculator not for other usages…
by
Has anyone encountered getting the wrong answers when there is a logarithm? Tried to on and off at first and worked but it doesn't work now, also tried resetting but it didn't help.
by
@Anfernee Jinang When you have different symptoms you should ask a new question rather than posting as a comment under an existing question.
by
Also there are only 3 modes left and the rest of the modes just got vanished.
Shift+7 Function is also not working any more.
Please help me
by
Show 1 more comment
Add a comment
Most Helpful Answer
If you have not tried the reset sequence here it is…
(CLR)
(Setup)
(Yes)
Score 1
1 Comment:
No.Still it's not working.I already did this work.My full calculator screen is reversed.
by
Add a comment
How's it going I'd like to try to help you fix your device so there's not a factory reset button on the back of it but you could try hitting shift 9 to enter the list then press 3 to reset all and then the equal sign to confirm it then hit the AC button to return it to normal then shift AC to turn it off reboot it see if it works like that then if that doesn't work you may try to take out the battery and getting a paperclip so the positive and negative terminals can reach each other that will help take out some extra electricity let it sit for 5 minutes then replace your battery
Add a comment
Hopefully that will help if not please let me know and I will be happy to continue finding things to help you out
1 Comment:
It is not working
by
Add a comment
Restart it change the battery
Add a comment
Add your answer
tanni tanni will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 47
Past 30 Days: 183
All Time: 7,417
