Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 Questions View all
Hdd HS12UHEA extract data.
Hi there!!! I have a HS12UHE/A rev. A, i need to extract the data from the hdd and i need a device or something that works with my model of hdd. Thanks in advance.
This is my HDD:
MacBook Air (Late 2008/Mid 2009) 120 GB Hard Drive
Score -1
Add a comment
1 Answer
Chosen Solution
Just get any type of external USB hard drive and hook it up. Then either drag and drop your data of for a recoverable hard drive backup, use Time Machine. Here's a plethora of them: http://www.google.com/search?q=external+...
Score 2
4 Comments:
Is not a sata normal device, is a lif or zif pin. Btw the macbook is logic board broken so i can't handle starting it or whatever. Thanks.
by
Dani, there are plenty of Zif-to-USB adapters out there that should work for you. If you take the Samsung model number and do a search for it, you should find what you need. Then you connect it like mayer suggest. You may need a different computer :-) to get to the actual files since your logic board is not working.
by
Is a lif to usb convert i need i guess. I was asking if anybody nows one that actually works!
by
Add a comment
Add your answer
Dani will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,206
