Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
Pink flickering lines - display
Not sure if the display is damaged. It works fine when I add pressure at the back of the laptop. The machine works as normal using a external screen, so it's not the graphic card. Please advice.
I uploaded a video: https://youtu.be/L7P1tycc-og - YouTube to see the issue in action.
Thanks
Score 1
Add a comment
1 Answer
Most Helpful Answer
You’ll need to pop off the bottom cover and inspect the LVDS connector & cable which is the big connector in the top right.
Just lift the clip tab so you can see the solder joints under it. Take a good picture and post it here for us to see. Adding images to an existing question
Score 1
Add a comment
Add your answer
Chris Binou will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 240
