Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Touch Screen not Working After Replacement
Hi ,
I’ve recently went to replace my 5s’ cracked screen to a new on only to discover that the touch on the new screen was completely unresponsive. Thinking I had a dud screen, I sent it back and got a refund.
I tested my original screen with my phone again and the touch worked fine.
Ordering a new screen again, I went to install it today and again the touch is completely unresponsive! The new screen is an original apple screen so I doubt it is faulty the second time, however I doubt my phone is faulty due to it working fine with the cracked screen.
Honestly any help on this would be appreciated, because im stumped.
Add a comment
Most Helpful Answer
The only thing I can think of is that you may have caused pry damage or long screw damage.
Did you put the screws back in the exact same location if not then that could cause long screw damage and prevent touch.
Score 1
Add a comment
Make sure all your ribbon cables are properly seated. Ive had similar problems with iphones not working and the problem simply was a bad connection.
Add a comment
Add your answer
kmes will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 58
