2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Questions View all
Just a handful of keys not working (MBP keyboard)
Hi! A few keys on my macbook aren’t working (including the J, K, L keys). I suspect it’s not a mechanical issue as they work when I’m logged into a guest account but not when I’m logged into my own account. If an external keyboard is plugged in, all the keys on the external keyboard work. The keys also work when I’m entering the user password for my account, which contains a K. I’ve tried a PRAM reset and an SMC reset. What should I try next? Thanks!
2 Comments
@ianthewolf Have you tried a clean install of macOS? be sure to back up your files if you have not and try this.
by
Hi Aaron, thanks! I have a backup so this is definitely a last resort I'll consider trying, though if there's anything else I can do first, obviously I'd prefer it :)
by
Add a comment
1 Answer
Chosen Solution
Did you install a key remaper app? As an example Resurrecting the MacBook's number pad
I would try deleting the keyboard import source and re-installing it when you’ve got the USB keyboard active. Thats the keyboard control panel in your preferences and under ‘Input Sources’
Score 2
1 Comment:
That’s really helpful, thanks! Fixed it :D
by
Add a comment
Add your answer
Ian K will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 68
