Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Loud Speaker (Buzzer) Problem
Hello friends. My device is iPhone 6 64GB. I'm having an interesting problem. First of all, the sound started coming less than usual. I cleaned it up, but it didn't change. Then I started to open it and check it out. First of all I removed the buzzeri and reinstalled it did not change. Then I just tried plugging in the sockets, so I didn't insert the bolts. I sounded soundly. I noticed that the speaker has a bolt on the right side of the screen. The sound sounds fine when you don't wear this bolt, but the sound decreases as if it's mono. I turned it off when I said that way. The sound was again slightly reduced, and then, when I tightened the two bolts on the case, the sound went down to the same level.
As I understand it, the sound is decreasing due to pressure. This is the case when you press the right-hand side of the screen. What do you think is the defective part? I also tried it with a robust buzzer, the same. I suspect a movie with a socket on the bottom. Thank you in advance if you have experienced this before or will find a solution
Add a comment
1 Answer
Chosen Solution
The sound “circuit” is based on the speaker, the Lightning Port Flex and the audio circuit on the logic board. If you have already tried replacing the speaker with a known-good speaker, then the next step would be to try a new Lightning Port.
Score 3
1 Comment:
Thank you, I will try. I hope so, fixed.
by
Add a comment
Add your answer
Murat Oz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 224
