The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 Questions View all
Replacing the joystick circuit board in my Xbox One S controller
I've been trying to replace the left joystick on my Xbox One S controller and failing miserably at removing the broken one with the soldering iron. So instead I want to attempt at just replacing the circuit board itself, but before I do I have a few questions.
  1. I'm going to use a circuit board from one of the older controller models for the first gen Xbox One, the one without a 3.5mm headphone jack. Will it be compatible with the Xbox One S controller I'm repairing?
  2. If it works, will the 3.5mm headphone jack still work even though the circuit board is from an older controller model?
Add a comment
1 Answer
Well there’s some good news, and some bad news.
The good news is that it looks as if you can put an original xbox controller board in a new controller body. Although I am not certain. Bad news is that the headphone jack will NOT work, as there is no physical connector to connect to on the older board.
Add a comment
Add your answer
knarrmatt will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 4
All Time: 608
