letters are always uppercase even after disabling shift key
every now and then theres an issue where the shift key (i believe ninety nine % because i cant type numbers) is always on> i used karabiner to disable shift key and assigned a different key to it and though it was fixed but no luck> i even just disabled shift key with no replacement and still didnt work> any help at all would be appreciated< computer repair said it wouldbe three hundred to replace keyboard
3 Comments
but i dont think its they keyboard as i disabled the key to no avail> words are in all caps as i type but dont appear so in the question
by jackstensgard
The shift keys are not functioning
But the caps lock is working but it’s still in uppercase
by ternasamuel3
Check the viewer to test your keys if they don't show up then you will need a new keyboard or uppercase which every you find easier.
by Dan
