The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Damaged logic board connector
Look closely at the trackpad connector on the board. I only say this because upon close inspection of the board in my 2015 MacBook Pro 13 inch, I see the far right end of the trackpad connector is broken. The end that anchors the cable to the board and the first one or two of the pins may have separated from their pads.
Since I doubt my client has opened the back of his computer, I suspect the damage was simply caused from excess pressure applied to the bottom of the computer. I see this often when computers are put in backpacks. Over time, this pressure eventually causes the end to break off.
Now I am looking for a replacement trackpad connector that I can microsolder to the board.
If anybody has a part number or knows the name of this part, please let me know. Perhaps somebody out there knows a company that sells logic board components? I’ve tried a few like Rossmann and beetstech without success. I have included images.
Thank you.
2 Comments
the first 7 pins seems to be in the circuit, have you tried to play a little with the connector and tried to force the pins back in to the original place, it might make contact and work out, if so you should apply something (like silicone glue) to keep the connector in the safe place. I don't know, its just an idea, because wont be easy to find that particular piece.
Also, you might ask around for a dead compatible logic board, and make the change.
Wish you luck!
by
Sorry to say someone was a bit forceful on the connector trying to put it on which is why the end is mashed. I have serviced tons of systems and have only seen this type of damage on previously serviced system (opened). If you don't line up the connector and press down this is what happens!
@oldturkey03 - Any ideas where to find the connector?
by
Add a comment
Most Helpful Answer
@wellconnected
that is a DF40BG-48DP-0.4V Hirose connector and only available in bulk at mouser.com as well as digikey.com. Of course you can check Alibaba.com and might as well even Amazon and Ebay….
Score 3
1 Comment:
Oldturkey, thank you. I'm off to locate a DF40BG-48DP-0.4V Hirose connector now.
I will keep you posted.
Oh, and btw, the ad at the top of this page indicate that there is only one Mac service provider in the Dallas area that can resolve this problem. We will see if I can prove them wrong by successfully completing this repair.
Chris Leeds
www.wellconnectedlife.com
by
Add a comment
This looks like a standard Apple connector—try to find a cross match from a different device. From far away it looks like maybe a match to an iPhone 4s dock or digitizer connector. If that fails, count the number of pins and search that number plus “connector” plus “fpc” on Aliexpress.
Score 1
4 Comments:
@jessabethany - I found what you where thinking Dock to Logic Board Connector (44 Pin) But he needs a 48 pin connector. I've used my last one from my junkers.
by
Thanks @danj for counting all those pins :)
I search aliexpress for 48 pin fpc connector and it's a match to the galaxy s3 display connector---not sure if the width is right, but dead s3 boards are everywhere.
https://www.aliexpress.com/item/5pcs-LCD...
by
Great ideas. Going to give it a shot. Will keep y’all posted. Thank you.
by
@jessabethany - I even tried counting them in italian ;-} Getting in to the habit as I'll be off in the next few years to Tuscany.
by
Add a comment
Add your answer
Chris Leeds will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 9
All Time: 607
