The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
I have a couple of questions regarding smartphones
  1. Someone told me that you need to find which pins are + and - on different components for exemple battery connector or charging ports. Why is that?
  2. What does it means when the multimeter beeps on continunity when checking one pin of the battery connector and yet the rest dosent. Checking them all against ground
  3. How do you close a circuit with a multimeter on a smartphone board and why do you need to do this
  4. When you remove a bad cap. Resistor or inductor which causes shorts. Do you replace it with a new one? If so. Where do you find new caps resistors and inductors that fit the specific phone your working on?
1 Comment
anyone can help?
by
Add a comment
1 Answer
Chosen Solution
This question sounds a lot like some kind of homework. Why are you asking these questions?
This question can’t be answered in a meaningful way without more context. I’ll ask you a question “What do you think the difference is between positive and negative wires in a phone?”
It means that pin is continuous with ground, aka that pin IS ground.
Closing a circuit just means putting a wire to connect two spots, same thing that happens when you flick a lightswitch, or lower a drawbridge. You ask how would you do this with a multimeter—-answer: you don’t.
Resistors and inductors can NOT cause shorts, so removing them to solve a short would be bad repair. Capacitors do fail in a way that they become the reason a line is short, so removing a bad cap to clear a short is reasonable. Replacing it depends on the function of the cap, and the difficulty in sourcing a new one and the technical challenge of replacing it. That is—if it is easy enough to replace then do it. If it will risk the whole device because clearance is limited, then skip it.
You find new ones at the cap store—mouser.com
Score 1
Add a comment
Add your answer
yanivpro will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 11
All Time: 54
