2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Questions View all
Replaced battery, Mac boots, Blank display, but external works fine.
I'm doing a repair on a prof's computer, I replaced a swollen battery on a Mid 2014 Macbook Pro retina, the external works ok, but the main laptop display doesn't... Battery came from amazon, listed on box as Late 2013 - Mid 2014 its from Egoway Model A1494, 11.26 volts 95 Wh 8440mAh Li-ion Polymer. could it be the battery? could it be the display?
UPDATE: someone worked on the macbook prior to me, they hosed the display cable on the top right putting the case back together. so essence… it needs a display.
Add a comment
It’s possible to “harvest” that eDP cable from a broken display (exact same model/year) and you’ll be good to go! Let me know if you find one & need to know how.
Add a comment
which screwdriver I need to open MacBook Pro?
Add a comment
Add your answer
Charles Dawson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 49
