Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
Why my iPhone 6s+ randomly reboot?
Hey guys. I have a weird problem.
I changed my screen and my battery. 1 day it normally worked. But today my charge percent changed %80 to %30 and o minute later it rebooted. So opened and my battery percent %1. So this issue still contiuning. Percent is wrong and I sometimes can charge it. I dont know its charging or not. Phone is laggy and rebooting frequently. My new battery is faulty or something different issue?
Thank you in advance.
Add a comment
Chosen Solution
Chances are battery is defective. Contact the seller of the battery for a replacement.
Score 1
Add a comment
Yes this sounds as if the battery is defective.
Add a comment
Thanks for answers. I changed my battery and I did fix it!
Add a comment
From your description this must be bad battery because you have symptoms of a gas gauge defect and most of the gas gauge line is within the battery in the 6/6s series. However if this were a device such as the iPhone SE, 5s, 5c, or 5 where the gas gauge line has an easy to knock off filter right at the battery connector, that when knocked off at battery change causes an open line on gas gauge then MOST LIKELY would revert to pry damage in that case.
Just wanted to add in case anyone reads this question but has one of the other devices.
Jessa of iPad Rehab
Add a comment
Add your answer
Semih S. Avcılar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
All Time: 196
