2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Refurbishing MacBook Pro 2012
This laptop has served me well for over 5 years and is still going strong. Thank you, Apple, for building a quality product.
There are three areas I may need upgrades.
I tend to keep many Chrome tabs open and that eats up much of the 8 GB memory. When I originally partitioned the disk, I didn’t allocate enough to Windows and am left with about 8 G available. I keep it mostly plugged in and the battery lasts about 2 hours on its own. So,
1- How do I upgrade it from 8GB to 12 or 16?
2- Should I replace the old 250GB SSD with a larger one or can I do non-destructive re-allocation between OSX and Windows?
3- How do I check my battery health and if needed, which aftermarket battery should I replace it with?
Thank you.
Add a comment
1 Answer
Most Helpful Answer
To check the status of your battery download, install and run Coconut Battery:
https://www.coconut-flavour.com/coconutb...
Standard RAM:8 GBMaximum RAM:16 GB*
Details:*8 GB of RAM is onboard. It originally could be upgraded at the time of purchase to 16 GB as a US$200 option, but it cannot be upgraded subsequently.
Here are some storage options, Transcend also make them:
https://eshop.macsales.com/upgrades/macb... If you get an OWC stick you can also get the Envoy enclosure. The you can install a system and use Migration Assistant to move you data. Afterward you can use the Envoy to put your old stick into for a Time Machine User data back up.
Score 3
Add a comment
Add your answer
Inquisitive will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 397
