Not starting after battery replacement
Hi, I followed this link - - - > MacBook Pro 15" Retina Display Mid 2014 Battery Replacement
I have all the tools and an anti static mat but after going through this 3 times my Mac will not boot. I get an amber light on the Magsafe charger, if I SMC reset the light goes to green but the Mac simply will not start. No fans no display , nothing.
Any ideas please?
Can you post some high res pictures of the area around the battery connector and the area around the PCH (The Large Chip to the left of the battery connector. Ive had quite a few of these come in my shop with resistors knocked off right under the PCH after having a battery replacement done, causing it not to power on.
by Henri Grimm
Hi, thanks this is done.
by Bob Murray
Can you disconnect the battery and try to start your laptop from charger only with battery disconnected? You want to rule out a bad battery.
by Rany
Hi, thank you. I tried this and it still does not start.
by Bob Murray
@bob_reno Hi what was solution please? My issue is same after battery replacement... Thx
by Martin Zápeca
