Screen displays picture then becomes VERY distorted.
While using my Mac Book Pro the screen started flickering as if it was receiving a bad picture transmission. Then, after about 20 min the image on the screen became completely distorted. I noticed that the sound and cursor still worked and as i moved windows around the picture became WORSE. I shut down the laptop by holding the power button and restarted it the next day. At first the picture was fine, however,, after 20 min or so the problem repeated.
Any suggestions?
Score -1
6 Comments
Currently on the laptop and when the problem happens, i tap on the bottom, below the screen hinge and picture comes back temporarily. Any other suggestions?
by
HEY, you may be able to get you a free repair but I need the last three letters of your serial number to know.
by
W0G are the last three of the serial #.
by
Apple MacBook Pro "Core 2 Duo" 2.16 15" Specs
Identifiers: Late 2006 - MA609LL - MacBookPro2,2 - A1211 - 2120
by
NEW DISCOVERY! So, after bringing my laptop to the office to test on an external monitor I noticed after 45 min that when I use it here(in my office), picture does not drop out. Weird.. I also failed to mention in earlier posts that my Power adapter has some wire damage and my battery needs to be replaced :/ so it is ALWAYS plugged in when in use. Any thoughts?
by
Show 1 more comment
Add a comment
Chosen Solution
If your graphic chip is a Nvidia contact Apple for a free logic board replacement.
Score 2
1 Comment:
thanks for that answer lem, if we knew which machine he had we would know that. Those are my toes, thank you.
by
Add a comment
Most Helpful Answer
Please give us the last three letters of your serial number. (found in the battery compartment), I'm pretty sure what the problem is but I need to know your EXACT machine. Hook it up to an external monitor and see if the picture distorts on both.
Score 3
2 Comments:
You do NOT have the Nvidia GPU, so no free logic board. This does sound like a GPU issue and the external monitor test will show that. If so you can get it reflowed or repaired. Here's one place that will do it: http://www.dttservice.com/macbookprosilv...
by
I'm unsure also of what your problem is. What did the external monitor test show?
by
Add a comment
It might be a cooling issue. Check that all the vents are clear of dust, when graphics processors overheat they loose quality, fast, and my result in a distorted image. The only other thing I can think of is to replace the ribbon cable to the screen. Plug an external display in to see if you can still use the computer and check the temps of the processor. Good luck.
Score 1
4 Comments:
how do i check the temp of the processors?
by
Dante, if you give the numbers as requested, you will get more precise answers and suggestions
by
Thanks for the responses mayer, although, I'm still unsure of what the issue may be... :/
by
by
Add a comment
Add your answer
Dante will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,342
