The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Questions View all
Can someone please help me find out what’s wrong with my MacBook Air!
Randomly the other day I went to go plug in my charger & it wouldn’t charge.. it said it was charging but it didn’t have the green light & it was still on 4% after I had it on for an hour well after a day or two it died completely. When I put it on charge it still said it was charging but wasn’t, I couldn’t turn it on so I searched YouTube videos & some unplugged the battery source so I did that & plugged the charger to it.. my computer would turn on if I had the battery unplugged & the charger connected but when I plugged the battery back in it would cut off, so right now I’m trying to update it while the battery is unplugged & it’s on the charger but it’s a struggle because every 10 minutes it keeps cutting off & I have to unplug the charger, plug it back in, & cut it back on to finish the update.
Add a comment
1 Answer
Chosen Solution
It's not normal in any circumstance that power would be missing every now and then, even with no battery, therefore you should be able to complete your whatever task without a problem. First thing to try is to borrow or buy a replacement charger, after checking your magsafe connector and plug are fine and there's no dirt. If this doesn't solve your problem issue might be more complex.
Score 2
2 Comments:
I bought a replacement charger, neither one of them charge it.. it says it does but it’s not actually charging. Like I said I unplugged the battery source, connected the charger to see if I could get the light to work on the charger & my computer turns on but as soon as I plugged the battery source back in it cuts off. But even with the battery unplugged & the charger connected my computer only last 30 minutes.
by
If system crashes even with battery unplugged it's very likely we're facing a component issue here. Hard to tell exactly what might be the cause without testing the logic board. Any liquid spills in the past ? I'm afraid you'll need to have your Mac checked in a lab where they do component level repairs or get it to Apple where they'll probably suggest a logic board replacement.
by
Add a comment
Add your answer
amberyoungpink will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 65
