Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Upgraded to SSD problems
I just upgraded from my stock HD to a 500gb Samsung860 evo SSD. Install went smoothly some problems with downloading the OS but got it working. Now after about a day of having it in it started to develop some problems, 1 it will be running normally then it will just completely freeze up, which I restart and it gods back to normal. 2. I’ll get a black screen where my pointer is still visible. 3rd I’tll be running normally then I’ll get a folder with a blinking question mark on it.
Add a comment
1 Answer
Most Helpful Answer
Replace your hard drive I/R cable. Put pads on either side of the cable as it climbs onto the optical drive to prevent the bottom from touching it. I use 3M extreme mounting tape to do this. For a while last year Apple was replacing this cable for free.
\MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement
Score 2
17 Comments:
To add to @mayer 's answer place some electrical tape on the uppercase where the cable rests as the rough aluminum surface wears the cable as well.
by
Thank you for your prompt reply, I bought a new IR and just finished Installing and to my dismay the problem still persists, any ideas?
by
@g2raw - Lets see if the system will run with this drive externally. You'll need a HD case FireWire or Thunderbolt being the better. Or USB to SATA adapter cable or case.
by
@danj just got it, no crashes or anything when plugged in externally
by
Then you've isolated the issue back to the HD SATA cable. You could have damaged the replacement or it was just a bad cable from the get go.
by
Show 12 more comments
Add a comment
Add your answer
George P will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 207
