Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
How to fix "press home to upgrade" , broken home button
hello, hye.
I was using my iphone 5s for 3 years now. Last year the home button broken. I still survive with assist touch. Now after a month update to ios 11 , the screen start to be unresponsive. My brother decided to hard reset , not knowing the broken home button. Now i am stuck at press home to upgrade . HELP. "slide to turn off" does not appear when i push the on off button. Long push to turn off the phone .
Score 3
Add a comment
1 Answer
Most Helpful Answer
You can change the button, its costed cca 5€, but never come the touch ID, only click... or open the phone put out the flex cable go to yout position i system where you are stuck on press homebutton, and make short with screwdriver on this flex connector.. (in the housing sitr, not on the old disconected button :)) with this "jumper" you simulate press the button...
Score 2
1 Comment:
I use the tweezer to short the connector.. and guest what it works.. the phone unlock and continue upgrade without home button.. :)
by
Add a comment
Add your answer
shailah.saranghae will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 15
All Time: 6,701
