Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
Home button won't work after glass replacement but touch ID does
Hi there,
Just replacement my iPhone 7+ front assembly today. Had to trouble shoot a few things along the way, but the oddest thing is happening now. The home button isn't working but touch ID/finger print is working. For example I can hit the power button and then place my finger on the home button and my iPhone will unlock but pressing it won't do anything. Any ideas? I've tried a reset (power + volume down button for 10 seconds) but that doesn't seem to do the trick.
Ideas?
Add a comment
Chosen Solution
There's a small IC on the Home Button flex which is easily damaged (the solder connections are damaged) when migrating it from one screen to another. This is fixable but it does require a micro-soldering repair and is not a DIY fix.
Score 2
Add a comment
First try restoring the phone on iTunes, if this has no success then check all the related home button connections as the black foam and easily get trapped inside the connectors, if still no joy try your old screen as the home button extension cable that clips to the logic board is easily torn where it bends through 180deg.
If non of these work then you have probably damaged the homebutton somewhere.
Score 1
Add a comment
the home button is connected Via the Screen assembly Flex.
make sure the screen you got has a functional flex. (using a second screen is the easiest way to test this)
there may have been damage to the flex. unfortunately replacing this home button is not possible as it pairs to the motherboard, and changing it will cause all function to be lost. a certified technician is your best bet for this procedure.
Add a comment
Add your answer
Jacob Cole will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 123
