The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Questions View all
Minimal liquid spilled, doesnt start after cleanig with isoprop?
Hi,
I've read a few topics around this but haven't got a handle on what to do.
So there was very little tea spilled on trackpad 3-4days ago.
Today I opened the Mac and looked for corrosion. I couldn't find anything unnormal, except for some dust which I cleaned carefully. I don't have isopropanol at hand for cleaning... should i look for some?
I get the error codes PFM006 and PPN001 from diagnostics. The laptop works somewhat fine, just slow. I'm writing this from it.
What I've understood is that this is related to a heat sensor. What are my options? As I couldn't see any visual damage on the board I'm wondering what should be replaced? How to further investigate the fault? Is there any workaround to lower the high kernel_task and high fan?
I've reset SMC. High fan and kernel_task high also in Safe mode.
Update (04/13/2018)
Do u see anything here?
I did remove the ssd and airport after the pictures.
UPDATE: Cleaned with isopropyl, no fix. What to do next?
UPDATE:
After cleaning the board a second time with isprop,mac wont start anymore... i removed the battery and still no charge light nor charge. I tried resetting smc. no help.did i break something? how to identify what?
3 Comments
Sorry to say the images are a bit dark (and not detailed enough) so I can't see the components discreetly.
by
Right.. I gave it a good clean with isopropyl but no help.. :(
by
Can you repost a set of clearer images
by
Add a comment
Most Helpful Answer
Did you remove the logic board completely from the uppercase? Often the other side gets the worse of it!
  • PFM006 is the SMC logic
  • PPN001 is the iSight logic
You likely need to look on the other side and clean it up. A soft toothbrush is what I use and just be careful! As you can easily lift the small SMT devices. Use a high grade isopropyl alcohol (85% or better).
IFIXIT guide: MacBook Air 13" Mid 2013 Logic Board Replacement
Score 2
2 Comments:
Thanks, I did completely remove it. However as I mentioned, I didn't use anything to clean, just dry toothbrush for the dust. I didn't see anything with my eyes towards corrosion.
I didn't remove the heat sink either.
I'll look for some alcohol for a better clean.. Thanks for your response.
by
A good clean with isopropyl didn't help. Same situation.
Anything to do next? If I need to replace something, how would I know what it is?
by
Add a comment
Check the I/O board and mainly the I/O cable for corrosion they will cause sensor failures and high fan speed. Also check the Trackpad flex cable and trackpad for corrosion.
Score 1
Add a comment
Add your answer
Henri Parviainen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 99
