Minimal liquid spilled, doesnt start after cleanig with isoprop?
Hi,
I've read a few topics around this but haven't got a handle on what to do.
So there was very little tea spilled on trackpad 3-4days ago.
Today I opened the Mac and looked for corrosion. I couldn't find anything unnormal, except for some dust which I cleaned carefully. I don't have isopropanol at hand for cleaning... should i look for some?
I get the error codes PFM006 and PPN001 from diagnostics. The laptop works somewhat fine, just slow. I'm writing this from it.
What I've understood is that this is related to a heat sensor. What are my options? As I couldn't see any visual damage on the board I'm wondering what should be replaced? How to further investigate the fault? Is there any workaround to lower the high kernel_task and high fan?
I've reset SMC. High fan and kernel_task high also in Safe mode.
Update (04/13/2018)
Do u see anything here?
I did remove the ssd and airport after the pictures.
UPDATE: Cleaned with isopropyl, no fix. What to do next?
UPDATE:
After cleaning the board a second time with isprop,mac wont start anymore... i removed the battery and still no charge light nor charge. I tried resetting smc. no help.did i break something? how to identify what?
3 Comments
Sorry to say the images are a bit dark (and not detailed enough) so I can't see the components discreetly.
by Dan
Right.. I gave it a good clean with isopropyl but no help.. :(
by Henri Parviainen
Can you repost a set of clearer images
by Dan
