Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
Unable to erase/inititalize Second Hard drive
I have installed a second hard drive in my Mac Mini using the IFIXIT kit. The drive is recognized by system but I cannot write to, erase or partition the drive.
I know the drive is working as I can mount it in an external case and it works.
What am I doing wrong?
2 Comments
Is this a new drive or one from another system?
You stated you had it working externally was this drive from an external WD drive case you opened to get the drive out? If it was then you can't use it as its hardware linked to the case's USB port logic.
by
No it is a new drive. I mounted it in my external test case to ensure the drive was functioning.
by
Add a comment
Chosen Solution
At this point I think the SATA drive cable is defective or got damaged in the process of the install.
Score 1
Add a comment
OK thanks.
That being the case I think I will just mount in an external usb3 case and connect to the new thunderport dock I have purchase.
Add a comment
Add your answer
Robert Thompson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 47
