Made by GM. It's the eighth generation of a land yacht!
24 Questions View all
How do I change the turn signal switch?
I've got no headlights and after changing the headlight switch to no avail I started changing my attention to the turn signal switch. I noticed it doesn't click when operated. So I need to know how to remove it?
Score -1
1 Comment
Do the wipers work?
by
Add a comment
Chosen Solution
Disconnect your main battery and let it sit for and hour then reconnect and see if the problem persists. (This does a reset)
Score 2
1 Comment:
Worth a try--can't hurt and the price is right.
by
Add a comment
Before you disconnect the battery, make sure your ECC (Electronic Climate Control, if you have that option) is turned OFF.
The ECC computer has a program flaw that causes it to overcycle the blend valve motor when seeking its original setting after you hook up the battery, which usually results in a broken gear inside the blend valve actuator. Then you have no control over A/C or Heat, the blend flap usually defaults to A/C which means no heat ever. Replacement of the blend valve actuator is awkward at best and very expensive at worst (most shops will take apart the entire dash to get access). Or if you are very inventive you can make a hillbilly workaround by disconnecting the actuator arm through the back of the glove box, and rig a manual control from coat hanger wire (not elegant).
Add a comment
Add your answer
ron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 2,884
