Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
Intalled new 2TB SSD / Computer will not Boot
I have a early 2008 24" Imac w/ 3.06 Intel Processor
I took it upoun myself to replace the HD with a SSD
I successfully(?) installed the SSD and then using my orig intall disc installed OSX 10.5.4
I then installed some updates
I then rebooted using the install disc and used Time MAchine to bring it back to where I was at
Time Machine took 5 Hours to restore
When I try to boot
No Chime
I first get a window that says "Your Computer Restarted Due to a problem"
it then attempts to boot again and I get a scary screen White Text in Black Boxes with lots of Tech jargon
Wont Reboot from install disc
I tried to reset PRAM and SMC no change
Please Help
Thank you
1 Comment:
What is the make and model of the SSD & how much RAM do you have in your system?
I recommend you run Mac OS-X El Capitan (10.11.6) with a SSD as this is the first release which supports TRIM.
by
Add a comment
I would try reinstalling the OS with the install disks, then from Finder, go into Applications > Utilities > Migration Assistant > and choose to restore from time machine backup. If the same thing happens, check check the minimum RAM requirements for your chosen OS, and also install SMC Fan Control. I've seen some strange things solved by SMC fan control--especially after an SSD upgrade.
2 Comments:
Skyejobs - You might want to re-read what the OP stated: "Time Machine took 5 Hours to restore"
Thats a long time! So we have a hardware level issue here, so trying to deal with OS and fan control software (which I personally don't recommend!) is not the focus.
The make and model of the SSD's need to be looked at. Remember this is an older system so what is the systems SATA port speed and what is the specs of the drive, is this a workable config?
by
I think @danj hit the nail on the head. The compatibility of a 6GB/s drive in a 3GB/s machine could cause issues.
by
Add a comment
So are you saying it works until you do the Time Machine Reload? If so, you might have something corrupted or some bad software in that back-up.
Add a comment
Add your answer
Barry Shapiro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 154
