Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
My screen was unresponsive
my screen was unresponsive and i restarted it multiple times it didn't work when i did that so i took apart the phone and disconnected everything . after that i connected everything back and i couldn't even turn the phone on
2 Comments
OK. what parts and how did you disconnect?
by
i took off the three flex cables that are connected to the screen, then i disconnected the battery.
by
Add a comment
1 Answer
Chosen Solution
If you connect your phone to an iTunes enabled computer, does iTunes recognize your phone as being connected?
If it does, then your problem may be backlight related. Shine a bright flashlight on the screen right after you connect it to iTunes. If you can see a dim image, then you may have blown the backlight circuit on the phone or damaged the backlight in the display assembly. This can happen when you disconnect the screen before disconnecting the battery.
If iTunes doesn't recognize the phone, then you may have other issues on the logic board.
Score 2
Add a comment
Add your answer
Kathrine Ybarra will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 57
