The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Update stopped halfway through and now can’t log back on
So yesterday I started to update my MacBook to high siera when it stopped and turned off my computer. So it reloaded at tried to log back on comes up with black messages at the top of the screen saying “Mac OS version not yet set”. After this it takes me to an error message saying “your computer restarted because of a problem. Any help would be appreciated
Add a comment
1 Answer
Most Helpful Answer
Do a reinstall from an external USB dive to the latest system.
UPDATE
You also have to install a bootable system on the USB drive. Then when you boot the machine (with the flash drive plugged in) hold down the option key and select the flash drive as your boot drib=ve. After it boots you cam run Disk Utilities on the internal drive and/or format it. Then install the system.
Score 2
5 Comments:
How do I do this?
by
Most people put a system install on their external backup drive. Others do it with a USB flash stick.
by
What steps should I follow to install it?
by
As @mayer said, If you have important things on it and not have back up , that will be different story. If you don't have important things and you want to reinstall the OSX using a thumbdrive, then you must create one with diskmaker X and OSX high Sierra , using another mac. There is also a small potential that the recovery mode can fix it , or even try to update the installer, but this will not guarantee success , or any data loss.
by
Once I put it on the usb, how do I install it
by
Add a comment
Add your answer
Taylor Sprigg will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 75
