Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
How to replace PRAM battery cable receptacle on logic board
I replaced my lower case on my A1260. when I removed the pram battery cable from the logic the whole receptacle came off the logic board. I need to get another receptacle to place on the logic board so I can reconnect the pram battery cable.
Score -1
Add a comment
Chosen Solution
Put the logic board in a static proof bag and take it to an old tech that does component level board soldering and give him 10 bucks to fix it. Mac PRAM batteries used to be soldered directly to the logic board so if he can't get the socket on just solder it to the board.
Score 2
Add a comment
Similar problem, I unsoldererd the cr2025 , cant remember which wire is the positive black or grey?
1 Comment:
use a multimeter to test it
by
Add a comment
Add your answer
Bryan Rose will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,034
