What is this this part called?
Hi,
What is this part called? I changed my flex cable and am wondering what it is.
Thanks!
Hi,
Thanks!
That is a hard drive/IR cable going into a hard drive bracket. You have selected the incorrect machine in your machine select (as you picked a Retina machine) and they did not use this. See if this 2012 non-retina is your machine: MacBook Pro 15" Unibody Mid 2012
This is the cable you appear to have (they should be a part number printed on the cable):
Thanks @mayer, you are right. It is an A1398.
Do you know how I can test the IR functionality after reassembling? The Mac is running fine again but I am not 100% sure if I put that tiny IR thing correctly together. Thank you !
Look on the back and check what the Axxx number is.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 50
