2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
What is this this part called?
Hi,
What is this part called? I changed my flex cable and am wondering what it is.
Thanks!
https://imgur.com/a/ySa9V
Add a comment
1 Answer
Chosen Solution
That is a hard drive/IR cable going into a hard drive bracket. You have selected the incorrect machine in your machine select (as you picked a Retina machine) and they did not use this. See if this 2012 non-retina is your machine: MacBook Pro 15" Unibody Mid 2012
This is the cable you appear to have (they should be a part number printed on the cable):
MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable
MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable Image
Product
$19.99
Score 3
2 Comments:
Thanks @mayer, you are right. It is an A1398.
Do you know how I can test the IR functionality after reassembling? The Mac is running fine again but I am not 100% sure if I put that tiny IR thing correctly together. Thank you !
by
Look on the back and check what the Axxx number is.
by
Add a comment
Add your answer
Albertus Craddle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 50
