Repair guides for different types of storage devices, ranging from internal hard drives to network attached drives.
633 Questions View all
A few SATA cable questions
#1 why on earth are SATA cables rated at 300 volts?
#2 how far can you safely (data transfer wise) bend or twist a SATA cable? (at certain points, like the middle of the cable, the connector ends of the cable)
#3 good idea or bad idea to use the cable shown?
the metal is exposed under the insulation.
zoomed in:
@danj @avanteguarde
5 Comments
photo is not clear enough to tell.
by
Ok hold on...
by
Go to the new photo via the web page and click on it then blow it up. Let's start over, tell us what you are doing.
by
@mayer I was just wondering If I would be able to use that one if needed or if it may result in corruption due to the exposed cable.
by
Add a comment
1 Answer
Chosen Solution
If you don't have any exposed metal showing, it should be fine.
Score 2
4 Comments:
So, the orange cable is a goner.
by
It maybe OK, the orange outer sheath covers the discreet wires which are shielded.
by
OK. as long as the shield is not punctured?
by
Each wire is shielded independently. The shields are tied together and the lines go to the pins. I would take a Ohm meter to check continuity and make sure the lines aren't shorted to the shields.
by
Add a comment
Add your answer
Aiden will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 67
