A few SATA cable questions
#1 why on earth are SATA cables rated at 300 volts?
#2 how far can you safely (data transfer wise) bend or twist a SATA cable? (at certain points, like the middle of the cable, the connector ends of the cable)
#3 good idea or bad idea to use the cable shown?
the metal is exposed under the insulation.
zoomed in:
5 Comments
photo is not clear enough to tell.
by mayer
Ok hold on...
by Aiden
@mayer there.
by Aiden
Go to the new photo via the web page and click on it then blow it up. Let's start over, tell us what you are doing.
by mayer
@mayer I was just wondering If I would be able to use that one if needed or if it may result in corruption due to the exposed cable.
by Aiden
