Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Is there a way to test the ambient light sensor?
I have recently had to replace my FCAM/Sensor assembly (my ear piece audio went out) and was able to use an app to test the proximity sensor but there is no such ability with the ambient light sensor. I move from a well light room to a dark room and don't notice any difference but I never really payed any attention in the past so can't really tell if this would be noticeable. Is there any way to test this? or even create a situation when where the shift in brightness should be clearly apparent?
Add a comment
Chosen Solution
Go to general-accessibility-display-accommodations. Look for Auto brightness toggle. Switch it off and on. Do this in a dark room. Screen should get dimmer with low light and vice versa. This is your test
Add a comment
Most Helpful Answer
There is a Auto brightness toggle in the settings accessibly display accommodation area.
Toggle that on and off and it should change brightness automatically when switched back on.
Score 2
2 Comments:
I just tried that but didn't notice any change. I disassembled the assembly again and noticed a black rubber gasket over the original light sensor, so I transferred that over and reassembled it and toggled the auto brightness again but still do not notice any difference. Am I missing something? Thanks!
by
Front camera assembly is faulty as Auto brightness does nothing.
by
Add a comment
The best way to test it is to make sure auto brightness is on, then when the brightness is all the way up, put the phone into sleep, put your finger over the sensor an wake up the phone. If it works, the screen should dim and get brighter when you remove your finger. (Do this in a bright room)
Add a comment
We just hold them under a bright light under the microscope and watch the screen dim or brighten as we move the phone to and from the bright light
Add a comment
Add your answer
Todd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 45
All Time: 17,678
