Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
75 Questions View all
Will Dell XPS 13 9360 motherboard work on my Dell XPS 13 9350?
I am replacing the motherboard on Dell XPS 13 9350 -i7 and currently have an option to install 9360 i7 motherboard. I think chassis (dimensions) are exactly the same, but I wonder if the new motherboard version works with older chassis/ older PC version?
Any advice/tip is welcomed.
Add a comment
Chosen Solution
UPDATE:
I was not successful installing this motherboard:
As was indicated by professional laptop service I went through, the potential problems are with the internal power supply and BIOS. And if the latter can be fixed, the former can seriously affect motherboard performance. The electric circuits diagram we found online did not explicitly indicate power levels, so we opted to use safest, ie older version of the motherboard.
Add a comment
Most Helpful Answer
Hi. I think in this case you most likely need to replace the battery and make sure your screen and screen cable are compatible with the new motherboard. P.S.This is all pure theory.
Cheers,
Yevhen
Score 1
Add a comment
Did you ever figure this out. I am trying to figure this out as well
1 Comment:
Hi, I was not successful installing this motherboard:
Apologies for being unassertive!
by
Add a comment
Hello,
I upgraded my 9343 to the 9360, I also bought the larger capacity OEM battery. The palm rest is also different, so buy a new one as well :)
Add a comment
Add your answer
Oikk Waclaw will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,677
